Re: water in 3 cylinders
Is this your first boat? And you have a little knowledge of car/truck engines right? Well, sorry, this is one of the BIGGEST, most common rookie mistakes. Sorry you wasted so much time replacing head gaskets.
The number 1 source of water in the cylinders of a marine engine is a bad exhaust manifold and or riser. That's what it is almost 95% of the time.
What did your manifolds look like when you removed them to change the head gasket? You are looking for LOTS of rust in the water passages, but more specifically, you are looking for rust streaks or cracks in the exhaust ports.
And obviously you realize that you don't want to let the water sit in the cylinders, or you are going to ruin the block, right?
