Help!! Need some parts.
witenite0560
I'm looking for a long shaft and shift rod extension for a 1959, v-4, 50hp, Evinrude Starflite. I'm restoring one that I bought locally. But, it was a short shaft and I need a long. I've got all the other parts, except the shaft itself and the extension for the shift rod.
If anyone has one they'd take some cash for, please let me know.
Thanks
Re: Help!! Need some parts.
I think I have the driveshaft. You might check to see if a dealer can get the shift shaft extension.
lindy46
I think I have the parts - PM me if interested.
Let me look and make sure I still have it. I converted my Fatty to shortshaft in 1976 or so, so the driveshaft has travelled extensively with me.
witenite0560
Can anyone tell me if the drive shaft (shaft from head to lower unit) for a 1959 Evinrude 50hp, Model 50519 might be the same as the drive shaft for a 30-35hp Lark. Don't know the year of the Lark, sorry.
Thanks
F_R
Thanks
Not the same. Nor is it the same as the larger V-4 engines (75hp, etc) The V4-50 was only made for 2 years, 1958-59. They did use the lower unit on a very few late-1960's 60 & 65hp motors as a "Heavy Duty" option.
OK, I have it. Let's make sure it is exactly what you need. It is 32-1/8 inches long overall. It is about 20-3/4 inches long from the top of the impeller to the crankshaft end spline. The splines on both ends have 4 male lobes and are 2 inches long.
If that is correct, and you want it PM me.
