need help with motor id
I am rebuilding my lower unit on what is suppose to be a 1987 johnson 150.the only number i can find is J150GTLCURR7566290,IS THIS A VALID NUMBER,WHAT DOES IT TRANSLATE TOO? PLEASE HELP,TIRED OF ORDERING PARTS AND THEY WON'T FIT!
Daviet
Re: need help with motor id
Ser# J150GTLCUR is listed under a 1987 150 HP. Could it be that someone has swapped out the lower unit from another motor. You might have to sit down with the parts breakdown and try and determine what you have.
Faztbullet
In late 1991 Omc went to a two bolt/tab design that holds carrier in place and a 2 piece driveshaft, if it has 4 bolts in the front of carrier its a 1991 or earlier. What parts are you needing as there was a propshaft diameter change also?
emdsapmgr
Any chance you have a commercial 155 lower unit on the engine? They have different parts.
ezeke
Most of the 1987 differences are between large and small gearcases. The large gearcase has 15 splines om the propshaft, the small has 13.
