Rstang1966
- Sep 25, 2009
- 5
I'm new to owing a boat and don't have a lot of experience with boat motors, but am pretty experienced when it comes to automation motors.
I have an old Ted Williams motor (217-5871-0) that I recently purchased and have been doing some work to on it.
Below is a list of things that I have done so far...
1. Disassembled and cleaned carb.
2. Replaced all fuel hoses.
3. Replaced plugs.
4. Checked compression (~100psi each cylinder)
(not off more than 5 psi compared to each other)
5. Replaced impeller.
6. Replaced lower end gear lube.
7. New fuel/oil mix.
8. Cleaned magneto contacts.
9. Checked for spark at each plug with a volt meter.
My first concern is that when i get the motor running and idling I have a very strong (solid stream) tell tail. However when I drive the boat and speed up the boat the tell tail slowly goes away until I have no water coming from the tell tail. Anyone have any thoughts?
Secondly while I was driving the boat around at WOT on one occasion the motor slowed (by its self) to the point that it turned off. I was able to immediately restart the motor and continue on my way. Seemed very weird but I'm not sure if its something that I should be concerned with.
Lastly the motor is pretty hard to start from cold. I would say that it typically takes me 12 - 20 pulls in order to get it started. Does anyone have any tips or things to look at to improve the ease of starting?
Thanks for the help..
3. Replaced plugs.
