krisnowicki
- Jul 11, 2007
- 1,172
So I got her running put a new carb on. I ran the engine at between 12-2000 rpms 30 mins. Here is what I got. I couldn't run it anymore because it was getting late and she is no quiet lady.
I have great oil pressure but nothing is showing up on the dipstick. I know the pick up and dipstick are in the right place. I have 5 and half qts of oil in and only a 5 qt pan. Do new engines need more then 5 because there was no oil in the engine to start ? I am think that I used grease on the dipstick to put it in and the grease may be clogging it up not allowing oil to get in so maybe I will try blowing air in it to clear it out.
The engine ran and sounded fantastic. she never got hotter then I could touch with a bare hand any where at any time. I did let it idle for the last min to check the timing ( but my light broke so I couldn't get a number) and to check the mixture ( it was spot on).
Should I drain the oil now or keep it for the first 10 hours then drain?
Is there anything else I need to do running wise before she goes in and I start the break in period via the merc manual?
