Evinrude 70
TRAVIS73
Smoke Coming From Out Of The Cover ,not The Exhaust.is There A Connection Loose Maybe.got Any Schematics Links?
jtexas
Re: Evinrude 70
welcome to iboats!
What year is this motor?
How long have you owned it? It was running fine before and this just started?
What recent maintenance has been done?
"Coming from out of the cover...can you be a little more specific? Where is the smoke escaping from?
Anything under the hood scorched or burned?
engine schematics are available free online at www.shop.evinrude.com click on 'electronic parts catalogues" but you won't find wiring diagrams there, for that you'd need a service manual.
TRAVIS73
Re: Evinrude 70
Looking At Buying The Boat,smoking Under The Cover.it Wont Run Under Speed Allthe Smoke Sucks In The Carb.89' Ev 70hp.no Smoke Escaping.
F_R
Re: Evinrude 70
There are only two ways that smoke can get under the cover.
1. Exhaust smoke leak
2. Paint burning from overheating.
Well, three. Wires burning.
mikesea
Re: Evinrude 70
is there any debris like a mouse nest in behind the prop not allowing the exhust out thru the prop,thats where it should be coming out
mikesea
Re: Evinrude 70
assuming the leak is under the hood,you have exhust cover on the port side kinda triangular with alot of bolts,or you have a powerhead mounting gasket down bottom of powerhead,then there is the adapter gasket thats below that.The path is it should go out bottom of powerhead thru the midsection where there is a exhust coupler with a gasget ,that then goes into the lowerunit flowing out the prop.Are you saying when the engine runs you get NO exhust out the prop,what can happn too is if there is anykind of backpressure ,even water if the piece between the lowerunit with the rubber gasket is missing,you can gert exhust up thru the midsectioncoming in the front under the carbs,some exhust coming thru an older engine is not unreasonable,but if nothing or very little is flowing in the normal path ,i would think the problem has to do with the exhust housing in midsection,see if the link works,look up your eng and see exhust housing,you could have a gasket under the powerhead bad http://shop2.evinrude.com/ext/index.aspx?s1=2495683ee5b3dbfbd36e4fb336a84b6c
jtexas
Re: Evinrude 70
there's an exhaust housing cover with a rubber seal just above the relief ports; if that seal fails, exhaust from the relief ports can get back up in there.
