Faztbullet
- Mar 2, 2008
- 15,933
Re: 73 johnson 115.. piston hits spark plug.
That engine uses perma gap plugs which are flat,
Thanks for that info but I don't see his 1973 Model 115 listed.
Surface plugs tend to run cold and foul to much. That is why a newer Gap adjustable plug is listed.
The QL77JC4, gapped at either .030 or .040 should operate perfectly in that engine with adequate clearance. Since it does not, at the present, I would agree with others to use the UL77V plugs or extra plug washers on the QL77JC4.
However, think about it...... from what I understand in your posts, it is only one cylinder that hits the QL77JC4 plug, and the same cylinder every time?
If so, I suspect that you have either piston play, one wrong piston installed, excess build up on the dome of one piston, or a shaved head or block. Unlikely that a shaved head or block would affect just one cylinder though.
really I'm just trying to come up with any excuse not to do any internal engine work.. i may try the ul77v and just use the boat the rest of the year and rebuild over the winter. hopefully it holds up, thank god for my towing membership. would I have to buy a ul77v for every cylinder or just the one? i don't see much build up, one of the first things i did when the engine was running was de-carb it too. it's pretty clean inside there... and a shaved block should affect both plugs on that side, or else i should have a gasket leak.
