I have 1990 mercruiser 4.3 alpha one out drive it runs very strong, although the other day when cruising through the marina at idle speed the water temperature gauge was reading 240 degrees, so I applied a little more throttle and the temp came down some. When I started cruising at a more normal speed the temp came down to 120 degrees. Is this normal?
