Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
1988 175 evinrude....runs great at idle..... at wot motor needs more fuel...i can push the choke and feel the fuel working... carbs are clean....any ideas?
yes, tried the bulb ....yes, to fuel filter, carbs adjusted.......almost feels like a vacum problem....going to try starting fluid test tomorrow around gaskets
Maybe a vacuum leak but typically it doesn't just happen when you open it up, it would run like a dog at idle. Idle would be lower if vacuum were an issue.Have had the carbs out and put a kit in them?
