What oil mixture for 2 stroke Johnson?
Jamie-C
Had the boat out for the first time from I bought it last week. Was unsure aout what the ratio was for the 2 stroke oil.
I searched the net and went for 50:1 but I'm still unsure so any help is greatly appreciated!
Its a Johnson 60hp made in 1972 (I think), the Model number is J60ELCIA.
If anyone knows I wouldly be very great full :D
Jamie-C
Re: What oil mixture for 2 stroke Johnson?
Definitely? :)
So to 20 litres of petrol how much 2 stoke would that be? Haven't done ratios in ages :(
Thanks
Daviet
Not any good with litres, but you need 1 pint (16oz) of oil to 6 gallons of gas.
Jamie-C
6 gallons is about 27 litres. So I should be using a bit less than a pint :eek:
I used far less than that when I took it out!
Is it definitely 50:1 for my engine?
jeff_smith_0423
this needs to be a sticky in the top secret file.
Hmm. 50 litres of fuel to 1 litre of oil. *whargrblasdflkjc* = 400ml oil to 20liters of gasoline.
Daviet
J60ELCIA is a 1981 60 hp.
50:1 is the correct ratio.
You probably don't get oil in pint containers, but here it is easy to mix, 1 pint can in the 6 gallon tank the motor came with and you are done.
Mixing the oil/gas is not rocket science, I would much rather run the ratio a little rich on the oil side than a little lean.
mike64
Definitely 50:1.
6 gallons is 22.7 liters. Dividing that by 50, I get .454, so a little bit less than 1/2 liter, if my math is correct. Say 1/2 liter to be on the safe side.
Also you should use marine TCW-3 rated 2-stroke oil. Bottles of marine oil usually have convenient charts on the back label showing how much oil for different amounts, in gallons and liter.
Jamie-C
Brilliant help! Thanks a lot.
I was running it far to lean when I had it out! Will get it right this time though :D
Thanks again
Tacklewasher
50:1 means 20 L of fuel divided by 50 = .4 L of oil (400 ml)
It really is a whole lot easier to figure out than pints/gallons.
Vic.S
Oh so true!
50:1 is 20ml oil to every litre of gasoline.
If percentages are your thing 50:1 is 2%
Jamie-C
Ah that makes a lot more sense to me, percentages are a lot easier to work out.
Will I notice any differences than when I had it running very lean? Accept the fact that my engine won't blow up :rolleyes:
Gary H NC
It may smoke a little more....nothing to worry about though...;)
Jamie-C
:cool: Cheers!
Can't wait to go out again now :D
