Removing lower unit on 2hp Johnson out board
traveldog
How do you remove the lower unit to replace the water pump on 2 hp Johnson outboard.
F_R
Re: Removing lower unit on 2hp Johnson out board
Hard to answer absolutely without knowing what year it is, but generally it is a simple matter of removing the two bolts and pull it off.
