old evinrude motor
tccjt
I have an old 10hp sportwin evinrude and I don't know what year it is. The serial numbr is 10014-13088 or 89. Could someone tell me what year model this motor is? Thanks. tccjt
asdasc
Re: old evinrude motor
Hopefully, you still have the 2 line gas tank and the connector to the motor!
Milemaker13
The old 2 line connectors and tanks are easy enough to come by. Check ebay and CL in your area. It's not difficult to replace the o-rings if yours is leaking. I have a '58 Sportwin. It still has the 2 line and it runs great. Have fun!
tccjt
Thanks for the info. I still have the two line hose and tank;however, they need to be serviced.tccjt
asdasc
Laings Outboards will have the tank rebuild kits. They sell the o-rings for the connectors here at i-Boats.com
Once you have done a couple of them, it is easy. The first one is a pain while you figure it all out, unless you can find the special tool. I went to Home Depot and found they sold 3 inch long, 5/16 diameter (I forgot what penny that is) hardened finishing nails and ground the point off one. It worked great for pounding out the brass in the end of the connector. After that, it was easy! I did them all.
The old tanks aren't hard to find, but unless you can find someone who doesn't know what they are worth, they can be expensive!
tccjt
What mixture is best for my 57 sportwin? Is it 50:1 or 24:1?
