Re: Transome size?
The problem isn't so much the the wood or epoxy is hard, its that it may only make contact in a small area, this concentrates the stress and "may" cause cracking. If the wood was in full contact for its entire length it wouldn't be such and issue. When epoxy is used to bed the stringer, its in full contact with the hull, spreading the load. Using consrtuction adhesive just spaces the wood off the hull so there is no contact, which works also. As I said though, for a transom its not an issue.
