tashasdaddy fuel pump conversion confusion
wrfalpacas
Ok, So I was reading tashasdaddys sticky, and it said to use fuel pump part # 18-7351
BUT IT IS LISTED FOR 9-15 HP, AND I AM WORKING ON A 1956 30 HP LARK. IS THAT STILL THE SAME SIZE PUMP, OR WILL I BE STARVING MY ENGINE FOR GAS:confused:
tashasdaddy
Re: tashasdaddy fuel pump conversion confusion
use this one. Part # 18-7352 for larger motors.
F_R
It won't starve for gas. It will be a direct fit for the listed motors as far as hose connections go. That doesn't mean that it won't work on your 30hp by routing the hoses accordingly.
henrye718
anyone have thoughts on a bracket to hold the pump? Mine was converted the pump is just laying in there.
tashasdaddy
henrye718, you must have a 3 hose pump.
henrye718
Yes. 3 hoses. Ah different then from what the OP was doing? I will look at the sticky. Someone who owned the motor before me did the work.
wrfalpacas
Thaks for the bracket info too!
