479Beachpeople
- Oct 17, 2009
- 2
Hi Having a new problem with my Yamaha. I went out fishing last week and the engine ran fine all day. When I was about half way back to launch I ran into some wind and waves. It started to slowly, smoothly loose power. I stopped and it idled fine, shut it down and checked for overheating, loose wires, low fuel etc. Everything looked OK. I started back up, took off with full power, so far so good then 5 minutes later it repeated the same thing. I would throttle back and idle for a few minutes and take off it would run OK for about 5 minutes the repeat the same pattern. I checked my fuel water seperator..... clean. I filled it before leaving with fresh Premium fuel. I am guessing, debris in one of the carbs or fuel pump going out? I pulled the plugs and #1 was slightly wet, #2 were light brown.I have a carb rebuilt kit and was planning on rebuilding them this fall. It seems like a fuel starvation problem. Any ideas out there?
