further
- Jun 18, 2009
- 1,034
I'm relatively new to boating (got a 1988 Maxum 1700MA w/ 85hp force) this summer and it's my first time winterizing. Just wanted to know how you all mix your gas and oil when you fill up an inboard tank - My tank is a 21 gallon and I just fillled it all the way up for the winter, then added the 50:1 ratio of oil and some sta-bil. My concern is that I'm not mixing the oil with the gas correctly as it all (the oil and sta-bil) seems to be sitting at the top. Should I tow it around town to shake it up a bit?
Also, i filled up the other day when it was a bit cold out (around 45 degrees) and today it was close to 70 when I got home from work i noticed fuel dripping out of the small vent - assuming the warm temps caused some expansion which caused it to overflow through the vent? Sorry if this all sounds a bit stupid, just trying to figure all this out and certainly don't want to run the motor if I don't have the oil/gas mixed correctly.
Thanks
Thanks
