ironworker
- Oct 20, 2009
- 5
i have a 74 evinrude 9.9 that insists on running on the number 1 cylinder only. quick rundown... good compression(105 in the number1, 110 in the number 2), fuel pump rebuild, new gas, carb cleaned inspected, new plugs, points filed and cleaned regapped. i felt like it was electrical so i started switching the electrical components to try and isolate the weak link. Coils, condensers, points, chased all the wiring for pin holes. number one runs on all of them, number 2 wont. number two cylinder has spark, (i have a compression spark tester gapped at 1/4 inch and the spark looks the same as 1) is getting fuel mix in the cylinder and is forcing unburned fuel out the exhaust. Starting to feel like a valve issue but i dont know enough... any insight would be greatly appriciated... by the way i am new to this site and already i have learned a lot. thank you to everyone involved
