spriessman\
- Sep 3, 2009
- 7
Bought the boat/motor on e-Bay. Obviously they weren't a "pair" when the boat was last licensed in 2007. The boat electric connections (female plug) have no mate on the Johnson RJE18. I'm wondering if someone just bolted some questionable motor on the boat to sell it.
We pre-oiled the top end of the RJE18 and mixed fresh oil/gas (8oz to 1 gal). Jumped a battery direct to the starter and after a few spins things came to life. Lots of blue smoke - no - LOTS of blue smoke with good cooling water discharge. Shut down after a few minute run and noticed quite a bit of oil in the trash can/test tank.
We dumped the trash can, refilled w/fresh water, fiddled to lean the low speed mixture, changed the hypoid in the lower unit and restarted. Ran for about 5 minutes........... and the engine smoothed out to a moderate low speed/start speed idle - no obvious missing or misfiring. Good cooling water discharge with no oil to the touch in the discharge water, lots of blue smoke and again, a fair amount of oil in the trash can. Pix attached.
What do you think??? Is this normal or have I got some major engine problem that's pumping oil into the exhaust???
Thanks for your help
Steve Priessman
steve@stevenpriessman.com
Steve Priessman
