I purchased a boat that came with a 1959 Evinrude Fastwin with Simplex controls. I removed all the steering and controls as I didn't like the space it took up. I got the motor running after about 100 pulls manually. Ran good. I went to start it one week later and choked it like I originally did. After I pulled a couple dozen times, I noticed the choke isn't working. Although I pull it out, nothing actually moves inside now. When I pull out on the knob, the lever inside actually moves away. Nothing else moves with it on its own. It used to when I first started it. I can manually push on it so it works, but that doesn't help much for convenience as I need the cover off and a third hand. It doesn't seem that anything is broken when I check the parts. I have never worked on boat motors and have minimal motor experience as is. Can't afford to send it to a shop. Any help would be great. Thanks.
