O.K. here's a good one.
Engine: 90-91 Carbed V135 2.0L V6. SN 0D009389
Problem: Stator replaced with new CDI direct replacement 16amp. I looked at the pics I took and put the pig tail in exactly the same spot as the old one. The pig tail comes out at about 5:00 with 12:00 being the crank.
Cranked it over on the spark tester and got good spark on all six. Put a timing light on #1 and it's out in left field. Check 2 and its in the ball park. 3 and 5 are whacked but 4 and 6 are good.
I swap switch boxes and get the same exact results. I remove the bias jumper (white/black) and remove the rectifier/regulator but the results are still exactly the same.
Finally, I swap red and blue on the inside switchbox (1,3,5) for red/white and blue/white on the outside switchbox (2,4,6) and low and behold now all 6 cylinders are in the ball park. The ball park is around 4 ATDC. Crank is indexed at .462 and dead on.
I'm thinking the stator that was on it was setup wrong and I now need to figure out where it's supposed to be.
I have a new set of switchboxes comming in tommorrow but I really don't think that's the problem. It's definitly not the trigger or I would have the same results on 2 that I have on 1 since they share the same trigger coil.
Thanks
Steve
Thanks
Steve
