Sacrificial Trim Anode Question
mwnitz
I want to replace all of my sacrificial anodes on my stern drive. I use in fresh water only, so magnesium is what I'm shooting for. Why is it that original equipment above my prop is a trim tab with a little fin so I can feel steering changes when worn, yet most replacement kits have a flat plate instead? In the Mercury manual #14, dated April 2001, page 1B-14, it reads 'an anodic plate is the new service replacement for the anodic trim tab'. What is going on? I want to replace what's on my drive with the same style. Any ideas?
dubs283
Re: Sacrificial Trim Anode Question
if the engine is equipped with power steering, the trim tab/anode will not do a whole lot
the trim tab/anode is designed for boats that have engines without power steering
if yopu have power steering, you will be fine with the flat anode
mwnitz
Thanks for the super quick reply. However, I do not have power steering.
dubs283
you will need the trim tab/anode then
it is available at any mercruiser dealer
mwnitz
Okie dokie! Thanks again for the fast response!! -Mark
bruceb58
Are your anodes worn away? Why would you change them if you only boat in fresh water? Do you leave your boat moored 24/7 in the water?
