drwatson69
- Oct 31, 2009
- 5
I know that it has a rev. limiter at 6100rpm. if and when the rev. limiter is activated does it stay active until key switch is cycled? I am new to this boat. it is a 1996 javelin 389t with a 1995 evinrude intruder 150 with a renagade bass four blade prop 14x25. when the tah says it reaches 6100-6500rpms the motor starts skipping. I back down to idle and it idles fine, but if I go to take off again it starts cutting out. now if I shut the motor off and restart it runs fine until i hit 6100-6500 on tach again. I am not sure the tach is right because the motor is not wot. which means the pedal is not all the way down. is this normal or is there a problem. I may be wrong but a 150hp on a 18'9" boat swinging a four blade 14x25 prop i dont think should tach out so easily.
