l just change the impeller ,l was told not pumping water,had to put oil in cylender to run motor,where does the water comes out from the back of the motor. thanks
I have a 1965 evinrude fisherman,Same motor and the tell tale is at the back of the leg just under the motor.If the impeller is good you should see a stream of water there
