Re: 89 85hp force
Now that you've identified an ignition problem, it makes trouble-shooting a bit easier. Not a cake walk but chances of fixing pretty good.
Double check the connections on the terminal block (I think it has 12 positions). This is where all the wires from the CD Modules, trigger and stator are located. Also check the ground wires from each coil to the mounting plate and the ground wire from the mounting plate to the engine block. Repair as needed. If this checks out OK, then move to the next step.
Swap #1 ignition coil with #2. If the problem now moves to #2 (pulling spark plug wire off has no affect on engine performance), the coil on #2 is bad. If no change (problem still stays with #1), you need to check the CD Modules.
Swap the two CD Modules that drive the coils. Be very careful to mark the wires before you start undoing them. You can really get yourself into trouble if you don't get the wires connected properly. You can take a poor running motor and turn it into a non-running motor very easily here. Anyways, if the problem now moves to #3 cylinder, you have a bad CD Module. If no change then you need to check the trigger and stator.
To check the trigger and stator you need an ohm meter. The trigger has three pairs of wires. #1 cyl has a green and orange pair of wires. #2 has red and white/green pair. #3 also has a green and orange pair. Disconnect one of the wires when checking each pair to eliminate anything interfering with your reading. Each pair should read 48 to 52 ohms between them. if readings are different, replace the trigger. If all is within specs, you need to check the stator.
The stator has six leads. Two green/yellow leads to charge the battery. You're not concerned with these. The two blue and two yellow leads are what you're concerned with. Measure between each blue and yellow lead. Remember, disconnect one side when checking. They should read between 680 - -850 ohms.
You should be able to narrow down your ignition problem by following these steps.
