primer bulb
chuffman
i have a 1988 classic 50, and it will run for a about thirty seconds and the primer bulb goes flat. It will stay running if you pump the primer. Any ideas? Thanks.
Bifflefan
Re: primer bulb
Replace the hose and bulb with a new one, OEM prefered.
Or open the tank vent????
mthieme
Re: primer bulb
Check the pickup tube in the tank for obstructions.
There is also a little valve at the hose connection on the tank that could be sticking.
abarron
Re: primer bulb
Thats was what was wrong with mine.I use a 5gal tank with seafoam added and it took care of my problem.My pick up tube was picking trash off the bottom of the tank.
