roscoe
- Oct 30, 2002
- 21,763
Re: Electricians - nightmare??
Bob_VT, if all else is as you say, this seems the most likely.
if there is power at the breaker...(you tested it right..? flipped it on and tested to make sure it had power at the terminal)
and no power at the first outlet you seen then that means that is not the 1st stop in the wire...the outlets probably feed from a switch power feed...I would pull the switches close also...
