1960 Johnson 5.5hp model CA-17. Bought used this past spring. Ran great all summmer and early fall. Started having having problems with dieing out when in gear. Since then I pulled carb off and rebuilt. Motor starts, runs, and idles great on stand. When put into gear on stand, it also seems to run good. When installed on boat and put into gear, in the water, motor slowly dies. In other words, this problem seems to only occur when a load is applied.
I am assuming that it could be a coil problem but before heading down that road I would appreciate opinions. Looking through the flywheel openings the insulation on the coils appear cracked/split due to age/heat.
Also ...any suggestions on a good source for parts for this motor, ie.. electrical parts etc... would also be appreciated.
THANKS IN ADVANCE!!!!!!
