ErieRon
- May 5, 2009
- 463
Re: MerCruiser 470 / 170 hp - Gauge Help
Sounds like you did it right. At zero pressure, you should have had 227-257 ohms. Just make sure your meter leads had good contact.
I think I have done this right, according to the manual.... regarding the Oil Pressure Sender.
I tried to put the positive connection on my ohms meter to the front of the sender terminal, and the negative to the back (by the bolt) to get a reading.... Absolutely nothing happened, so I removed the sending unit and tried again. Still nothing.
Does that mean I need to replace it if nothing was read from it? Or did I just do it wrong?
