Sharkbaite
- May 8, 2009
- 26
Ok lets try this again, I am still trying to get the drive off my boat and I have tried two different ways and neither one is working....
I have tried kncoking the pins out, no luck.
I did finally manage to get the upper unit lifted up and turned, but cannot pull it out, I had to remove the lower unit first though as the coupler would not slide down, no biggie... I cannot get the upper unit to pull out, I have tried putting a wench on it pulling it while I used a slide hammer, 3 days later its still in there.... Tried prying no luck either.
I am also trying a different approach by trying to remove the bell housing and the exhaust cradle from the inside, I have the 6 bolts removed for the bell housing and the 4 bolts for the exhaust, do these just pry/pull off or is there another trick. I am thinking if I can get in closer to the u-joint coupler I can get some pb blaster and possibly remove everything in one unit from the boat and then have a shop rebuild it.....
Any ideas would be helpfull.
I will be back on the boat tomorow to pull off the exhaust and the bell housing but ran out of time today...
