Evinrude 35 lots of blue smoke and some white? bad idle
flatsfishing
Re: Evinrude 35 lots of blue smoke and some white? bad idle
Hmmm I actually just replaced those not to long ago...
Cofe
Had a similar problem with a motor awhile back. I replaced the exhaust gaskets, and the gasket the powerhead sits on. Fixed the motor, but don't know which gaskets did the trick.
flatsfishing
Well thanks a lot cofe Im gonna replace the one the powerhead sits on first since its Ultrablue RTV lol and I will keep everyone posted..
kenmyfam
Good Luck. Hope it works out.
Cofe
Ok flatsfishing, yea a real gasket should do the trick. RTv is good stuff, but as hard as the powerhead is to get off, it's best to do it right.
On my last gasket set I purchased, I went down to the automotive parts place and bought a sizable chunk of gasket material. Then set down at the table and traced all the gaskets I could onto the gasket material. After that, I rolled up the material and placed it with the other Easter eggs in my shed. Now if I have a bad gasket, I have a back up......if I can find it.....Keep us posted on how things go.
flatsfishing
Sure will thanks again Cofe.
Thanks Kenmyfam
also thanks to everyone else for your input!
flatsfishing
Well heres a little update changed the exhaust gasket, Seafoamed it and got some new plugs which I am gonna put in tomorrow. I ran it for a while with the old plugs but they still seem to be getting soaked in gas? or some s not too sure... so well just see how it goes with these new plugs.. Im hoping the old ones are fouled out and this is the problem...
coolguy147
since you seafoamed. recheck compression. check spark?
ever clean the carbs?
flatsfishing
Checked spark looks good.. I only ran Seamfoam through it for 30min.. It seems like water is getting into the cylinders... could the exhaust gaskets on the side have anything to do with water going in there??
tx1961whaler
Yes.
bktheking
That and head gasket leaking as stated way back.
ezeke
When you replace the exhaust gaskets be sure to do both of them, use gasket sealer not RTV, torque and re-turque after running.
Sure you don't have water in the gasoline?
bktheking
Ahhhhhh the head gasket !!!!!
I remember that post !!!!
The powerhead has to be gone threw to find the water intrusion problem, it could be a gasket, cracked block, who knows. It shouldn't be running like that and blowing steam out the exhaust ports/tell tale.
flatsfishing
Well tomorrow Im gonna check those gaskets get some new fuel and if it doesnt work then im just gonna get rid of it I have already put way to much money into it...
Thanks for everyones replys
kenmyfam
Don't give up on it, you will get there.
bktheking
Get rid of it??? The limited edition james bond black 35 HP motor :eek:
coolguy147
ill take it :rolleyes: been looking to upgrade to a newer motor anyways
flatsfishing
Well I redid the exhaust cover gaskets put new fuel and it still didnt work, so this is it for this motor. I have spent over 700 dollars and cant remember how many hours..:mad: anyways thanks to everyone who took their time to respond to my thread:)
