1987 150 XR2 Oiling.
James R
The oil pump drive gear around the crankshaft is destroyed. I have been told that the motor will run ok without the plastic gear. I have also been told that there is a nylon disc dummy gear which is available to make the seal that the original gear provided.
Can someone please clarify. I will be rebuilding shortly.
Thanks.
Dukedog
Re: 1987 150 XR2 Oiling.
Tha oiler gear has nothin' ta do with "sealing". It does have a little ta do with takin' up space in that clyinder. Other wise know as "stuffin'". Gets that clyinder (crankcase pressure) closer ta tha same pressure as tha rest. On a lake motor you will never know tha difference if ya just throw it (trashed gear)away. Just use a block off kit with tha stem on it and never look back........
Faztbullet
100% Dukedog!!!! And to my knowledge there is no such dummy gear...
j_martin
The block off kit keeps the oil pump shaft end bushing busy so it doesn't fall into the motor.
John
James R
You have, as always, been very helpful. I thank you all and wish you a merry Christmas.
