JunoNormandy
- Dec 13, 2009
- 2
Firstly, please excuse my naivety with this subject as I am new to boating and outboards.
To cut a long story short and get straight to the point, I own a 1975 650 Mercury ?Thunderbolt Ignition? that no longer runs attached to a 16ft runabout.
Compression Test Results: Two cylinders both have 120psi, 3rd cylinder has 0 psi.
I suspect a broken rod as this was owned by a young lad before me (over revving perhaps) never assume!
Ignition Test: No spark from plugs.
Fuel Test: There is plenty of fuel getting to the carburetors.
It?s pretty clear this whole motor needs a good overhaul however, my main issue here is the compression and whether I am about to embark on a wasted journey to try and fix whatever the problem maybe. (read too many negative stories)
I would be much appreciated If anyone can pass on advice or experience they have had with compression issues and if they were successful and what my next steps should realistically be regarding the compression issue.
I appreciate your time in answering me and hope one day I will also be able to help others.
Cheers!
Cheers!
