got the idea to repair and use the original stringers from the Rot Doctor. But I tend to agree that since I'm already this far along it would make sense to use new dry wood..What type of wood do you suggest? Thanks for your help..It is my understanding that rot is caused by bacteria in the wood. If that is true it seems to me that even if you cut out and replace the bad wood you still run the risk of rot in the remaining wood. I know that mahogany is used in boats because of its resistance to water and its longevity. I can see why you would want to keep it. Another consideration is how wet the wood is. The wood needs to be completely dry before any fiberglass is applied to it. this could take months. Even treated wood is normally dried before use under glass. If the boards are completely wet it is unlikely that when they dry they will hold there shape.
If it were me, I would build new stringers and keep the mahogany for some fine cosmetic pieces. (trim or such) I?m sure aged mahogany would finish beautiful. (after it is dry of course)
Thanks for the info about the spruce. I would prefer to use a solid wood product than ply for the stringers. My transom needs to be replaced . Should I do my stringers and floor first and then the transom? I'm not going to remove the "Cap". The boat will stay on the trailer while I do the repairs.The boat guy at the place I go recommended that I use spruce for my stringers. After doing some internet searching on it I found that it is used quite a bit in the marine industry and it is reasonably priced too at a lumber yard.
Mick
http://forums.iboats.com/showthread.php?t=365820
