My prop is shot dented dinged and in need of replacement.
I have two different types of days at the lake. The first consists of fishing days with three people. On these days hole shot is less important but a little more top end would be nice. More time is spent cruising the lake. These are the more common types of days. The second type is family outings. On these days we pull tubes water ski and generally have around 5 people on the boat.
I am trying to decide if it would be better to go with 2 aluminum props one for each type of day or one SS prop. I am ok giving up a little performance if I can get two props that fit each situation better. I have no where to start so any advice on prop pitch, 3 or 4 blade and 2 alu vs one ss would be appreciated.
I boat at around 5000 feet in deep mountain lakes.
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
19p aluminum came on boat
3) Current prop diameter and pitch (required).
19p 14.5 oem
4) Wide open throttle RPM and speed with an average load (very helpful)
4500 rmp speedometer doesn?t work
5) Engine/drive make, model, year, and HP
4.3 mercruiser alpha 1 2002 1.81 gears
6) Boat make model, year, length and weight
Rinker 180 2002 18.5 boat weight 2300 dry 2800-3000 loaded
19p 14.5 oem
