Arrow trailer lights
Greebo
Hi all,
I have a US import trailer branded "Arrow" that was fitted to a Wellcraft Excell 18SX (1993).
It has oval shaped lights tail/brake that fit into inserts in the trailer rear rail. These appear to be sealed.
Can I get into them? (I have a blown light) for repairs, or must the whole light be replaced?
If I need to replace the lights, can anyone advise where they can be obtained from? (I'm in Australia so will need to be able to contact the seller on Internet).
Any advice at all is appreciated.
I also have a post re prop on this boat, if you have missed it but can supply any information please check it out.
Hope you all have a merry, but safe, Christmas and a happy and healthy New Year.
Greebo
Greebo
Re: Arrow trailer lights
As always, this site gives the goods.
Thanks very much - I was unable to find this site myself.
Merry Christmas.
Greebo
Greebo
Spot on - these are the lights.
Thanks
Greebo
MRS
Greebo, I am redoing my trailer now and will replace the same type of lights. I did remove them so I could put new lites in but can't figure how to get new one's in with out breaking them? How did you do your's......
woosterken
mrs,
just make sure the rubber groumet they ride in is seated tight in the hole,then take a little liquid dish soap,put it on the rubber and the light,they will slip together,then rinse the soap off and the light should be tight!!
to remove the light,reverse the process above,
I used these lights on my semi for years,and this is the way to do it with out damage.
hope this helps
woosterken
MRS
woos, Thanks thats sounds good will do this weekend when putting trailer back together Thanks again.....:)
Greebo
That's the same method I used as well except I used trusty WD40 for the lube. I'm really impressed by these lights (well, actually I'm really impressed by the whole trailer). Excellent quality.
Greebo
MRS
Greebo
Hey, Thanks guys I am putting trailer together now hopefully be finnished today fishing next weekend.....:)
MRS
Thanks guys went right in like you said sorry the photo is so dark but worked on it all day. But all I need to do now is paint fenders and bolt them on.
woosterken
I love it when a plan comes together :)
you going to paint the fenders the same color?
that be a lot of blue
woosterken
MRS
woosterken
That's what the wife said, the boat is blue and grey so I am going to paint them gray should look good I hope.....
woosterken
how much trouble would it be to but the boat back on there to check the look? and then maybe just use gray primer on the fenders,then if you dont like it ,you dont waste time with paint.
woosterken
MRS
What colour do you think would look good I was thinking gray or maybe black? I am going to put boat back on trailer before mounting fenders I can remove and mount fenders with boat on. I was also thinking of get new aluminum diamond plated fenders but not sure what will look better.
woosterken
ok, when i painted my trailer white and the fenders , it was way to much white!!!
i tryed a blue pin stripe the same color as the boat. :(
so i went with diamond plate and like it way more!
ok :) so i painted the letters on the tires white! we have LOOONG winters in ohio !
woosterken
MRS
Hey the aluminum fenders look good I might have to go that why also.:)
woosterken
one more suggestion for you, get some of that dialectric grease or plain ole vaseoline and slop it on the plug after you plug in you new lites.
keeps water from getting on the little fingers on the inside of the plug
woosterken
MRS
Good idea will do Thanks.....
ezmobee
I think those diamond plate fenders would look awesome on your already great looking trailer. Nice work.
