Mercury malfuntion lamp and harness
raymor
I was wondering if anyone would know where I could purchase a Mercury malfunction lamp and harness P/N 91-884793A1. This would allow me to read fault codes off my Four Stroke 115hp built in 2005. They call this out in the Mercury Shop manual but I have been unable to find anyone that sells this diagnostic tool. Think it would be great to keep on the boat in case of a break down..
Faztbullet
Re: Mercury malfuntion lamp and harness
You dont need it, just get a small lamp replacement assy from auto parts, remove connector and stick wires into diagnostic connector and count flashes, sort of like Goverment Motors OBD 1 system.
raymor
Faztbullet, I was going to do that except the newer motors have a little different setup than the old two wire lamp setup. They seem to have a third wire that connects somewhere else down below the connector.
Faztbullet
Still will work, third wire is for malfunction lamp. Just stick one wire in black(grnd)terminal and other in the blue/white terminal.
raymor
Thanks Faztbullet I will make up a harness and try it out. Think it would be nice to have one aboard just in case I have a break down out on the water and it is something easy to fix..
