Just like the title says.
Its a combination of a 1968, 1971, and 1977 6hp
I took the entire thing apart (except the powerhead) and sandblasted every last part. Then I got bored and sand-blasted the corroded hardware too, which was pretty much all of it.
So, the stainless bolts are no longer shinny looking, they are dull. By sand blasting them, did I take off some kind of stainless coating? or are they OK to reuse?
Secondly, I have no broken bolts on anything. everything came out, some were tighter than others, but not too bad. I got lucky. But, should I still clean up all the threads in the mid section and similar areas?
I'm assuming I need a tap and/or dye for this. Something I don't have, and have never used. Nor do I possess the knowledge of correctly using such tool.
So, do I need to do anything to the threads? if so, how do I use the tap & dye?
also, anti-seize. Should each bolt get some? if not, which ones do?
I have a bottle of the Johnson/Evinrude brand, gasket compound (type M? or F?) would that be ok to use? (someone said it would be fine)
