Re: VHF Antenna
BOATIST--Your theory that ground wave VHF radio communication range is increased more by antenna gain than by antenna height is not a widely held opinion, at least among people who don't base their radio propagation theory on what they read on a WEST Marine website. Again, just look around and notice all the very tall towers on which radio antennas are located. Why would anyone go to the trouble and expense of building and maintaining a tall tower for their radio antenna if the smart money was to use an antenna with double the gain at half the height?
Jhebert
Please do not misquote me.
I never said communication range is increased by antenna Gain ever.
What I said was increasing antenna height will increase range to the horzion.
Increasing antenna gain can help you get thru on busy radio channels.
Increasing Antenna gain does not increase range but does help you get thru on a busy channel.
The example was a Coast Guard antenna on top of a 3000 foot high mountain has a range of 77 miles.
On the VHF Marine raido
Two boats 70 miles away trying to contact that Coast Guard Station at the same time.
One boat with a 3 DB gain antenna mounted higher up.
Second boat with a 6DB gain antenna mounted mounted lower.
Then the station the Coast Guard will here is the boat with the 6DB Antenna.
Out here on a weekend or if we ever have another salmon there are many boats out.
Where we fish out of is about 25 miles North of San Francisco and has a Coast guard station but their antenna is not very high.
So if you need to call the Coast Guard will often get Group San Francisco instead of Bodega Bay.
San Francisco will often have many boats out. They may have Navy fleet week and have thounds of boats out.
They could have a Sail boat race and have many spectators.
In swells less than 5 feet will always have lots of fishing boats out.
To Raise them on the VHF Radio from 70 to 80 miles away can be hard but your chances are much better with a 6 db gain antenna.
You could raise a 3 db antenna 50 feet and it would not help at all.
The problem is not range as they are in range with even a low antenna.
The problem is being heard thru the traffic.
On your boat You can not here traffic more than about 12 miles away so do not know if someone is on channel 16 or not.
Coast Guard can here boats 77 miles to the north and 77 miles to the south.
Aslo 77 miles West out to sea and more than 80 miles inland. They have at least 6 antennas.
So the chances that someone is talking on channel 16 on a nice summer weekend are pretty high.
My chances of being heard by them is much better with a 6DB Gain antenna.
This is why most boat to boat transmisions should be made on 1 watt.
Boat to Boat is normally 10 to 12 miles range at best and 1 watt works just fine at that range.
This allows a boat sending a MayDay call with 25 watts and 6 DB gain for a effective radiated power of 100 Watts to be heard by the Coast Guard over the call to your buddy to switch and answer on channel 68.
MayDay of other saftey Transmissions should be made on 25 watts
Many Places inland you can listen all day and never hear another boat and only hear the Coast Guards Marine information brodcast.
In these locations a 3 DB Gain antenna would work very well.
I also never said I based My Radio Propagation theroy on what West Marine Said.
The West Marine Information was just to let you hear the same thing I said from a difference source wrote a little different to help you understand.
I could have wrote the article but everything they say is correct.
The 3 foot 3DB antenna can be the a good antenna for many. Most sail boat use it on the mast head.
Many who do not like the looks of a 8 foot antenna also use it.
The 8 foot 6DB is the best antenna for many also. I lay my antenna down on the deck before I hit the road so it is not going to hit anything.
Most times also cover the antenna with a 1 inch nylon tube that has two snaps.
A snap at the top that snaps to my deck where the camper cover would snap on and a snap at the base.
The cover keeps the sun off, stops antenna from scratching the deck and hold antenna in place.
My information is based on 50 years of Radio classes and experience.
40 Years of Ham radio.
a Master Course in Communication Electronics.
An Antenna Course and building and tuning many antennas.
I started with Building 2 CB radios in the 1960 and then moved to Ham Radio.
To get Your Novice Licence you have to understand Radio Propagation, it is a big part of the Novice Ham Radio test.
VHF and UHF are LINE of SITE and that is why they are mounted on high buildings or mountain tops.
Repeater also on top of high building or mountains but also have many rules on Antenna gain and radation pattern and power out.
HF will bend over the horzion Some and also SKIP.
Long wave and Low bans will bend over the horzion.
