Ok I have a 1996 Evinrude 200hp 60degree, with 6 carbs, if you know this motor this one is one of those that have the plastic carbs..ok , my problem is that one of the carbs , if you are inside the boat looking to the carbs the the bottom one at the the left, spits gas out of it every couple of seconds,I pull the plug and it looks wet, I had a problem, the motor was running rich , there was to much smoke out of the exhaust, I rebuild the 6 carbs and now I don't see that much smoke and it starts very fast , but still that carb spits, ...I swapped the carbs and still the same problem, swapped, the wire , plug and coil from another cylinder and still spits the same cylinder , checked the compression and is good 110psi per cylinder..any sugestion..thanks
