Aquaholic5
- Jan 19, 2010
- 12
Hello, first time poster..Long time reader. Great Site!
Anyway, I'm doing some stringer repair and bonding in a new deck. My boat appears to have been manufactured with Poly Resin and a Gel coat put over that. The Hull as well as the deck. So, I plan on using Poly Resin again.
Couple questions:
1)When preparing the surface, I need to grind/sand down through the gelcoat and get to bare fiberglass, then clean down with Acetone before applying the new poly? Poly doesn't like bonding to Gelcoat, even if its just scratched up good, correct?
2) Am I ok to use this cloth to bond in the new stringers, deck to the hull and for a layer on the new deck? I was planning on coating all of the new wood with 2 or 3 coats of CPES before laying down the final glass. Here is a picture, I found it at the local AutoZone. I plan on using a Poly Fiberglass Resin found at HD.
Thanks for any insight..I'm pretty green over hear, in case you have noticed
Good Day.
Couple questions:
Good Day.
