FreeBeeTony
- May 15, 2002
- 3,995
What type of hardware are the (2) screws that hold on the trim senders on each side of the drive? Stainless steel? I would like to replace them when I replace the bellows......
So SS it is........might add some antisieze when I install them.
From everything I have read, antiseize is a no-no when it comes to stainless steel and aluminum and salt water. Regular grease works better. It also helps to remove them and grease them again every now and then - before they bond themselves permanently into the aluminum.
Permatex Aviation form a gasket. It works great in salt water, better than grease.
