baconbiscut
- Jul 11, 2006
- 364
This is not a mechanical question is first thing I would like to say. Our Formula 25 PC was re-powered back in 2007 with Mercury's MerCruiser 383 Mag MPI engine. After about 200hrs of use I changed props and really screwed up the engine. I heard what sounded like a knocking sound so I took it in I had tulliped two intake valves. So I had the heads refinished and the intake valves replaced with stainless valves.
Anyway, after about 75 hours of easy running the ticking came back, however, after the engine had warmed up ran in the upper RPM range for a while the ticking went away. When I took the boat in for it's 100 hour (now 300hrs) I asked the mechanic to look into it. He ran the engine and he said it deffinately sounded like a knock or a spun bearing. So I had him pull the engine (I've got a bout grand worths of labor into it now) and tear it down. He called me later to tell me he had bad news. I went to the shop and he showed me the engines crank shaft had scoring where every bearing was it was so bad you could drag a nail through the scoring.
So he pulled up some data on the engine and the engine was supposed to have stainless intake and exhaust valves, which it actually didn't have. I have the old valves to prove to this. My mechanic believes that Mercury didn't clean the block out right and it damaged the bearings from the beginning because he said there's no way the crank shaft could have this kind of scoring from just normal running even if the engine was lugged. The mechanic called mercury and they seemed to want to help even though the engine was out of warranty.
If Mercury isn't willing to offer some sort of compensation should I demand it. Or is this one of "Your SOL situations". Also could this be my fault if so what cause the crankshaft scoring there was no debris in the engine. Anyways, any help or advice is greatly appreciated.
BTW, sorry for the long post
-Dan
-Dan
