fishgillz
- Jan 21, 2010
- 3
Well this all starts about 2 years ago... I had a few problems with my 1996 225 johnson so I changed the power pack, the stator, and the idle timing base. That fixed the original problems. Now the boat starts up fine but the idle is all nuts. It floats around 3000 rpms and sounds horrible. (like it's coughing) I ran it with two year old gas and that was a horrible idea. So we cleaned out the carbs and got some new sparkplugs and same problem. Now when I unplug 2 of the sparkplugs while the engines running it doesn't effect it at all. So my friend says I have two bad carburetors. I changed around the "working carbs with the "NOT" working carbs and no change! Whats broken here? It's been a LONG journey fixing this engine so any help will do!!! And if you can't tell I don't a ton about mechanics besides what I'm learning on this engine so speak in lamens terms please!
