Kill Cord for an old Johnson
Sandro1936
Hi there,
My Drascombe Dabber Giulia is driven by a 2 stroke Johnson 4hp of 1984 that does not feature a kill cord switch.
As I often sail/motor single handed, would it happen to me an unintentional fall over the side, it would not be a pleasant one the sight from astern of her chugging merrily away leaving her master bobbing in the wake.
I considered a few options, none of which looks practically viable:
1) Leading out of the flywheel plate two wires paralleled to the points and using a modern kill switch and cord by the trade.
2) A loaded spring, triggered by the kill cord, pushing the throttle control all the way down.
3) A rubber flap shutting the air intake.
Is there anybody that has confronted the problem and can suggest a solution?
Of course I wear a harness when single handed but neither being towed in the water is a pleasant experience, let alone the propellor danger.
I am posting this question both on the Practical Boat Owner and on the iboat/Johnson & Evinrude Outboard forums. I expect that multiple posting is not against forum etiquette. It?s just to widen the search.
Sandro
Vic.S
Re: Kill Cord for an old Johnson
I reckon a modern kill switch and cord connected as you suggest. But I said that on PBO's Reader to Reader forum.
Nobody here knows what a Drascombe Dabber is, that's the trouble.
Should post a picture
Well that's bumped the post up
samo_ott
Hook up a kill switch to the points. Is the easiest, most common method used. I would not consider any other method.
Sandro1936
Nice picture, VicS! Thank you.
But the boat herself is not involved in the search.
Is there someone that can tell me the exact size of the thread of the three holes on top the flywheel of a Johnson 4hp J4BR-CRM of 1984?
samo_ott
The older ones are 1/4" x 20 pitch thread. I would assume the same for the newer ones... And you should get grade 8 hardened bolts.
Vic.S
and 1/4" by 20 tpi is a coarse thread ie UNC not UNF.
It is the same pitch as Whitworth but as you will know the thread form is slightly different. For something like this I would not risk using Whitworth esp because whitworth bolts are not usually high tensile.
FWIW the holes in my '84 6hp flywheel are 1/4" by 20 tpi .. I just tried a 1/4" Whit bolt in them!
Sandro1936
Samo ott: thank you
VicS: thank you. Seeyou on PBO Reader to Reader.
