Re: rust on galvanized trailer
Galvanizing is nothing more than a coating on the steel parts. It's a zinc rich material, similar to the primers used on aluminum outboards.
There is galvanizing and then there is galvanizing. Hot dip, cold dip, etc. You can also buy spray-on galvanizing, which is usually used on repairs on older parts. Eventually, all galvanizing will wear off and then the metal will rust. Its just a matter of time and how well it was galvanized when manufactured. Fatseners on the trailer frame usually rust first, thus some rust streaks may be seen on the frame. It may only be from the nuts and bolts though.
Years ago some manufacturers bought galvanized metal, then formed it into the trailers. The coating on the bends usually failed first. Today, most reputable manufacturers form the trailer parts first, then galvanize them in-house.
I boat in fresh water, so the galvanized trailers I see here that are rusty are usually 30 years old or so. I would guess that salt water usage will accelerate the process.
Maybe more than you needed to know.
