Re: Cracked Gelcoat
You will have to grind it out regardless. When the gel is removed you'll see if it is cracked into the glass. If so that also has to be ground out and some glass put back in. Just remember whatever you do with your repair to fill, if your repair does not recede the surface you will end up with a halo in the gel if in fact you don't burn through when you sand it.
