duckaholic
- Jan 29, 2010
- 2
I have a 1973 Mercury 40 4 hp short shaft which cranks first or second pull and idles perfect. It will idle in forward and reverse for long periods of time (10 minutes). However, when put under load (throttled up) the little motor will run for a minute or two then shut down. I can pump the bulb until it is hard again and it will repeat the afore described. I have removed the carb, taken it apart, thoroughly cleaned the carb, reassembled, and the problem is unchanged. Is this potentially a fuel pump not suppling enough fuel? or a vacuum leak? All suggestions or recommendations to cure my ailing little motor would be appreciated.
