Re: 1966 Johnson 40HP outboard - cooling
Yup - thermostat is under the cap with 3 bolts. You can test it by suspending it in a pan of water on the stove. Heat the water and check with a thermometer and see where it begins to open. Don't let the t-stat sit on the bottom of the pan. I use a fine wire to suspend it. With the t-stat out, check the water passages and see if they are gunked up. To replace the impeller, you need to drop the lower unit. You'll see the 6 bolts holding it on, but there is another large bolt at the back of the motor which is hidden. You have to remove the rear exhaust housing to get to that bolt. It goes through from the top. The exhaust housing is held on by a bunch of Phillips head bolts. If it has a manual shift, there is a small oval plate on the side of the leg which you must remove to get to the shift rod coupler. Remove the bottom bolt from the coupler to free the lower shift rod. If it is electric shift, there are two wires which must be disconnected under the exhaust housing. Once the shift rod or wires are disconnected the lower unit should drop down. The impeller is under the water pump housing on top of the lower unit.
