2stroke1971
- Nov 8, 2009
- 210
I just bought an 86 capri with the volvo 4 cylinder and penta outdrive.
I wanted to just bump the motor over to make sure is spun ok, but the key switch did nothing. I assume it works like a car, the right most spring loaded turn would crank it.....
So I went back and jumped the solenoid with a screwdriver and all I got was a high pitched whirring....
as if the starter was spinning but certainly not turning the motor over. I was able to grab the main pulley by hand and roll it somewhat...Im gonna go throw a socket wrench on it and make sure the engine will in fact turn over freely....
Does this sound like a stripped starter gear? I wonder if that gear is replaceable or am I looking at a whole new starter? I guess I should pull the starter but any ideas would be greatly appreciated....
