mr_bobby_k
- Feb 2, 2010
- 4
ok..here we go, it seems i am not the only one who has had this problem. I have a 1996 Johnson 130. Problem started on a cold morning, i was idling in the boat slip, idled out of the "no wake" zone and was ready to get on top...motor wouldnt get past 3000 rpm...top speed was 6mph. I pulled the cover off and did the old "grab each plug wire" trick...they all shocked me. I took boat home. I changed all my coil packs and plugs and wires, i bought an in-line tester(as opposed to a timing light) and each cylinder has fire. In the driveway i can rev to 5500 rpm. So i thought problem solved, wrong, took boat back out and same thing..idles great then no fire in gear. I have checked all my compression and that is not the problem...i have all new plugs, wires, and packs. I am sure it could be the stator, or power pack...but i was hoping that someone might have had this problem also. i have read some threads that said a "shift interrupt" switch could kill a bank of cylinders on some bigger hp motors but i dont think i have one on mine..if i do i cannot locate it. Also i have read about the power pack having a S.L.O.W. mechanism in it which limits the motor to 2500 rpm in overheat, but this doesnt make sense if i can rev to 5500 in neutral...I run my boat all the time, carbs are immaculate condition, fuel filters changed monthly....not bad gas either....please help.
